Build attribute table fails when projecting ESRI 10 m land cover raster
3591
6
07-27-2021 07:01 AM
agrade132
Hello all. I recently downloaded a tile from the new 2020 ESRI 10 m land cover data (as a tif), and I notice that when I go to "project" the raster to an Albers Equal area projection, I lose the attribute table with the categorical land cover variables. Once I go to "build attribute table," it fails with an error 000049. Build attribute table will work with the original tif file. I checked and when I project the raster, the bit, band, and unsigned don't change. How do I fix this issue?
Thank you, Aaron.
DanPatterson
MVP Esteemed Contributor
make sure you save it as a *.tif .  Save it to your project folder. See what the raster type is then.
... sort of retired...
DanPatterson
If you are using the
Project Raster (Data Management)—ArcGIS Pro | Documentation
Did you make sure that you used the Nearest option to maintain the categorical values?
agrade132
Thank you for replying Dan. Yes, I did do that, and I just reran to double check and it still failed with the same error.
DanPatterson
What is the input and output raster information then?
Build Raster Attribute Table (Data Management)—ArcGIS Pro | Documentation
The exclusion as listed in the help is
You cannot build a raster attribute table for a raster dataset that is a pixel type of 32-bit floating point.
Which shouldn't be the case for categorical data.
agrade132
The input raster is: TIFF, single band, 10,10 cell size, unsigned integer 8 bit. WGS_1984_UTM_Zone_12_N, Meter, Degree.
I then used Data management --> Projections and Transformations --> Raster --> Project Raster. Used NEAREST as the sampling technique, selected WGS_1984_Albers for Output coordinate system (no geographic transformation).
The output raster from that process was in GRID format, unsigned integer, 4-bit, 1 band.
Could it be that it converts to 4-bit that's the problem?
DanPatterson
agrade132
Yes, that did the trick! When I saved it as a *.tif I'm able to see the attribute table without having to build one.
Thank you!
