"Publish this file as a hosted layer" option doesn't appear
1537
07-07-2020 05:30 PM
KelaineRavdin
I'm trying to upload a .csv file to create a hosted feature layer. I click Add Item > From My Computer, but the box that appears does not include a "Publish this file as a hosted layer" option at all. I have administrator privileges. What am I doing wrong?
Thanks!
Tags (1)
by Anonymous User
Not applicable
Hi Kelaine Ravdin‌,
The dialog included in the image looks like what you might see when logged into a free, public account. Can you confirm that you are in your organization (does the URL say orgname.maps.arcgis.com...)?
If you are logged in to your organization, can you test creating a hosted feature layer from a template (Create > Feature Layer > From a Template > Build a Layer > follow the prompts to create a hosted feature layer)?
Hope this helps,
-Peter
AntonioHornstein
I am following the " Creating and Sharing GIS Content Using ArcGIS Online" tutorial exercise 1, step 6, trying to view an tile package as a layer in AGOL. When I bring in the tile package it only allows me to open it in pro or desktop. Back to publishing as a tile layer, in the New Item window, there is no option to Create a Hosted Layer. Not sure what the issue is. I am logged in through my organization and should have the necessary authorization for this task. Any help or advice is appreciated, thank you.
AntonioHornstein
Sorry, here is an image of my window
KellamBartley1
I am having the exact same problem with the exact same tutorial. Very disappointing to see no answer for this after 10 months.
