QUESTION: What API did AOL/Portal developers use to develop Map Notes?
3563
11-25-2015 01:17 PM
SeanNakasone
I notice that the graphics in AOL/Portal support text, and also some graphics (like lines and rectangles) will scale as you zoom in and out, and map notes can be save to a JSON file on the server.  So I would like to create something similar using a web api .
I know there's the Graphics module in ArcGIS API for JavaScript, however these graphics do not scale when you zoom in/out.  For example, if you were to zoom into 1:1000 scale, and draw a line/rectangle, then zoom out to 1:50,000 , the thickness of the graphics will not scale down and the graphics will overlap each other and start getting grainy.  And there's no way to place text.    I know you can add graphics to a feature layer, which would be saved, but then each type of graphic (point, line, etc) would need a separate layer, and we would need to have separate layers for each user.
Are there alternatives to using the basic Graphics and Feature Layer modules in the JavaScript API ?
SeanNakasone
Correction.  The line thickness does not scale in AOL/Portal.  But I guess I still would like to know how to display text and how to save the graphics to a JSON file on the server.
