Problem displaying filter in Map Viewer
3891
08-11-2021 06:22 AM
DavidBarry
When opening a map in the new map viewer that was created in map viewer classic, I get the following error when attempting to access the filter. The layer is an AGOL feature service.
RussRoberts
Esri Notable Contributor
Can you share the map and I can take a look at the expression? This is expected in some cases but I can double check what is causing the message to be shown.
DavidBarry
Sure, see attached.
RussRoberts
thanks! if you can share the map and layer to a group I can take a closer look. Just need to invite russell_jsapi into it.
Aardwolf
Hi David,
Do you have any other settings such as view distance active on the layer?
This sometimes happens to me for two reasons. The Filter fields for the feature class are not visible, or the view distance has been changed in such a way that the layer never shows up.
This is just a shot in the dark, but I hope it helps.
EricErtl
I am running into the same issue with ArcGIS Enterprise 10.9.1.  Did this ever get resolved?
