Printing Issues - Post June 2026 Update
307
06-30-2026 02:53 AM
JonathanMcD
A note for UK colleagues.
In the UK we are lucky enough to have a public sector agreement in place with the Ordnance Survey meaning we have access to a number of high quality basemaps, services, and datasets. We also have access to a stack of services provided, in partnership with the public sector agreement, by a third party supplier.
As of the latest update, the ability to print from a WMTS basemap has been lost. Any resulting output is blank with only the added data and template outlines being shown. We use the OS MasterMap Topography base as an organisational default.
This will be raised as a support call later today once I get through some of the other issues.
PS - 5 credits per custom template print is a little excessive for a service!
StephanieW
Hi @JonathanMcD Thank you for sharing this. I tested with another WMTS layer as a basemap in Map Viewer and was able to print successfully. The Support Ticket should help isolate and narrow down the specific reproduction details.
David_McRitchie
Hey Jonathan just gave this a test with an OS service and didn't see any issues, perhaps there is something specific to the custom template that is triggering this.
I'll keep an eye out for the case when it comes in.
Many thanks,
David
Esri UK -Technical Support Analyst
JonathanMcD
@David_McRitchie
Hi, thanks for the response - issue happens with both the ESRI templates and custom. You're correct, when using something like the OS Maps API the basemap is shown, however, to use OS Maps API can only be seen as a limited time work-around as we're limited to Roads, Outdoor, Light, and Leisure stacks.
As with many things post-June update, everything worked perfectly the day before, to only be broken once the update had been deployed.
