I am trying to make a line chart in the popup from a related table of inspections. The Arcade expression spits out data, but the chart does not work.
Any idea how to get the chart to work?
Thanks
AJ
Code
// Get the related table
var table = FeatureSetByName($map, "Monitoring");
// Feature's matching ID (Name)
var myID = $feature["Name"];
// Array to hold features for chart
var features = [];
// Loop through table rows
for (var row in table) {
// Only include rows matching the current feature
if (row["CulvertID"] != myID) {
continue;
var d = row["Date"];
var h = row["AverageHeight"];
// Skip invalid or empty data
if (IsEmpty(d) || IsEmpty(h)) {
continue;
// Push attributes as needed for chart
Push(features, {
attributes: {
Date: d,
AverageHeight: h
// Return data for popup chart
return {
fields: [
{ name: "Date", type: "esriFieldTypeDate" },
{ name: "AverageHeight", type: "esriFieldTypeDouble" }
geometryType: "",
features: features
Results
dictionary
features: array(5)
0: dictionary
attributes: dictionary
AverageHeight: 34.25
Date: Mar 5, 2025, 8:47:34 AM Eastern Standard Time
1: dictionary
AverageHeight: 34.83
Date: Mar 12, 2025, 1:39:34 PM Eastern Daylight Time
2: dictionary
AverageHeight: 34.17
Date: Mar 19, 2025, 2:59:09 PM Eastern Daylight Time
3: dictionary
AverageHeight: 0
Date: Mar 27, 2025, 2:15:07 PM Eastern Daylight Time
4: dictionary
AverageHeight: 0
Date: Jun 18, 2025, 8:52:35 AM Eastern Daylight Time
fields: array(2)
0: dictionary
1: dictionary
geometryType: ""
AJ,
Below is code I have used to pull from historic hydrant flow tests (in a related table) to display flow and pressure data as a bar chart.
var MAX_TESTS = 10;
/* ───────────────────── 1. Fetch flow-test rows ───────────────────── */
var PORTAL = Portal("https://arcgis.yourportal.com/portal");
var ITEM_ID = "";
var FLOW_LAYER = ; // table-id for flow tests
var FK_FIELD = "FACILITYID"; // foreign-key in table 6
var fields = ["flowrate","residualpressure","staticpressure",
"testingdate", FK_FIELD];
var flowTests = FeatureSetByPortalItem(
PORTAL, ITEM_ID, FLOW_LAYER,
fields, false);
/* WHERE FACILITYID = '<current hydrant’s FACILITYID>' */
var facID = Trim(Text($feature[FK_FIELD]));
if (IsEmpty(facID)) { return; }
var where = FK_FIELD + " = '" + facID + "'";
var tests = Filter(flowTests, where);
if (Count(tests) == 0) { return; } // no matching tests
/* ───────────────────── 2. Build per-metric lists ─────────────────── */
var ordered = OrderBy(tests, "testingdate DESC"); // newest → oldest
var attrs = {};
var flowFlds = [];
var resFlds = [];
var staFlds = [];
var used = {};
var rowsAdded = 0;
for (var rec in ordered) {
if (rowsAdded == MAX_TESTS) { break; }
if (IsEmpty(rec.testingdate)) { continue; }
var base = Text(rec.testingdate, "YYYY-MM-DD");
var lbl = base;
var dup = 2;
while (HasKey(used, lbl)) {
lbl = base + " (" + dup + ")";
dup += 1;
used[lbl] = true;
if (!IsEmpty(rec.flowrate)) {
var k = lbl + "_flow";
attrs[k] = rec.flowrate;
Push(flowFlds, k);
if (!IsEmpty(rec.residualpressure)) {
var k = lbl + "_residual";
attrs[k] = rec.residualpressure;
Push(resFlds, k);
if (!IsEmpty(rec.staticpressure)) {
var k = lbl + "_static";
attrs[k] = rec.staticpressure;
Push(staFlds, k);
rowsAdded += 1;
/* oldest → newest for chronological bars */
flowFlds = Reverse(flowFlds);
resFlds = Reverse(resFlds);
staFlds = Reverse(staFlds);
/* ─────────────── 3. Linear-regression trend caption ─────────────── */
function captionLR(flds){
var n = Count(flds);
if (n < 2) { return " (trend unavailable)"; }
var sumX = 0;
var sumY = 0;
var sumX2 = 0;
var sumXY = 0;
for (var i = 0; i < n; i++) {
var y = attrs[flds[i]];
if (IsEmpty(y)) { return " (trend unavailable)"; }
sumX += i;
sumY += y;
sumX2 += i * i;
sumXY += i * y;
var denom = n * sumX2 - sumX * sumX;
if (denom == 0) { return " (trend unavailable)"; }
var slope = (n * sumXY - sumX * sumY) / denom; // Δy per test
var arrow = IIf(slope > 0, "▲",
IIf(slope < 0, "▼", "►"));
var txt = Text(Abs(slope), "#,###.0");
return arrow + " " + txt;
var flowCap = captionLR(flowFlds);
var resCap = captionLR(resFlds);
var staCap = captionLR(staFlds);
/* ─────────────────── 4. Assemble the charts ─────────────────────── */
var colors = [
[48,67,77,255],[8,97,107,255],[0,118,132,255],[0,140,153,255],
[96,124,151,255],[39,153,137,255],[115,140,167,255],[137,158,179,255],
[161,178,196,255],[188,206,221,255]
var charts = [];
if (Count(flowFlds) > 0) {
Push(charts,{
type:'columnchart',
title:'Flow Rate (GPM)',
caption:flowCap,
value:{fields:flowFlds,colors:colors}
if (Count(resFlds) > 0) {
Push(charts,{
type:'columnchart',
title:'Residual Pressure (PSI)',
caption:resCap,
value:{fields:resFlds,colors:colors}
if (Count(staFlds) > 0) {
Push(charts,{
type:'columnchart',
title:'Static Pressure (PSI)',
caption:staCap,
value:{fields:staFlds,colors:colors}
if (Count(charts) == 0) { return; }
/* ───────────────────── 5. Return Chart ──────────────────── */
return {
type : 'media',
attributes: attrs,
mediaInfos: charts
