Overlapping features - Identifying
600
10-02-2012 11:25 AM
danielsmith1
Does anyone know how to handle overlapping features. We would like users to click on the feature to get the attribute information, but what do you do if there is more than one overlapping? Only the topmost is ever selected.  thanks
MikeMinami
Esri Notable Contributor
Which application are you using? The ArcGIS Online Map Viewer will return all the results. You can use the small arrows at the top of the popup to navigate through the results.
Mike
SeanMcGuire
Is there any way to order or sort the identify popup results?  I would like to sort the results by draw order front-to-back for example.  It seems random currently.
Sean McGuire
