(noob alert) How to use the following file
688
01-08-2022 10:06 AM
MicheldeBruijn
Hi there,
I'm trying to upload the following file (under 'downloads') and it ought to work according to the website.
Wijk- en buurtkaart 2017 (cbs.nl)
Yet when i try to upload the zipfile I get an error. I must be overlooking something trivial (to you guys) and help would be much appreciated!
Regards,
Michel
HuubZwart
I assume you're trying to upload the file to ArcGIS Online. Be aware the file contains pdf files as well as shapefiles, I'm not sure how well ArcGIS Online handles that as it recognizes the shapefile and classifies it as shapefile. Anyway, just uploading seems to work for me:
- Download the file locally
- Click new item in the content page
- Select "Your device" in the upper panel
- Navigate to the local file
- Select "Upload zip only" (this is where you might get there error if you're trying to publish a feature layer from the selected file)
You're good to go
HuubZwart
You're good to go
