New Map Viewer Table Data Not Visible
1116
02-23-2022 12:20 PM
TracyMoy
In the Map Viewer Classic, my table data shows up, but in the New Map Viewer the table is completely empty, however the content of each field will show in a pop-up and will show if I configure a label.
The table I'm trying to use is added to our AGOL content, it is a feature service in our GDB made from a PostGreSQL View in Amazon Aurora. It does require login using our active directory credentials, but that seems to be working. It prompts me to login when I access it.
RussRoberts
Esri Notable Contributor
Are you able to check the developer console and see if any errors come up?
