New Map Viewer Save error
9972
13
03-25-2022 12:57 PM
gisetc
I have a map I created in Map Viewer (not Classic) and I recreated a layer. I added to Map Viewer, restyled, edited some field headers, and tried to save the map. I received an error message that states:
Failed to save map
Invalid value for property 'excludedLabelsVisible' which should always be 'true'
I'm dead in the water and on a deadline. I looked up that error message online and tried some different solutions that didn't bear fruit. I don't even know where to go from here and any help would be greatly appreciated.
Thank you!
Anita
DanielleKulas
Hi Chris,
Yep, I definitely had the filter panel open yesterday when I was saving!
Danielle
ChrisWhitmore
Great, thanks for confirming @DanielleKulas !
leightmaes
Hi Chris, weighing in here as well as I'm having the same issue but it is reproduced in a different way than described. I receive the "Failed to save map" error, "Close the Filter pane before saving". However, I do not have the filter pane open, but I did have the issue where it is a duplicate layer that should have had a filter copied when it was duplicated, but the filter did not come across in the duplicate and I added a new one. Once I added the new filter, and tried to save my map, it throws this error. Now even if I remove the same filters, it still does not permit me to save my map.
Any updates on the patch or the workaround would be greatly appreciated - let me know if you need further info.
Cheers,
Leigh
bbollin
Hi there @leightmaes. If possible, can you please provide the data you are working with and some steps to reproduce this? I tried to add a layer with an effect and filter applied, then duplicate the layer and save. I don't see an error here
