New domain values not available for new feature type
1155
01-18-2024 11:40 AM
Labels (3)
JohnsCreekGIS
I am having trouble adding domain types to my Site Considerations feature layer and having them display in editor to add them as new points. I added all of the types into the domain; however, when I go to edit and add a new feature all of the old ones I removed are still there (minus the symbology) and the ones I added are not even options.
After looking through some Community Posts with similar issues, I found that if I go to Map Viewer Classic I can go to Manage in the edit panel and remove the old types. The problem I came across is that it gets rid of the default visualization for some of the types. I guess those icons are not supported by Map Viewer Classic. I have several maps I need to configure with this and if I have to go back and forth between MV Classic and MV, it will take forever.
My question: Is there a way to 'Manage' the editor in the new Map Viewer rather than Map Viewer Classic?
EmilyGeo
Hi @JohnsCreekGIS, Providing a way to manage feature templates within Map Viewer is on our future road map. In the mean time, you can use either Map Viewer Classic or the Field Maps Designer app.
To manage feature templates in the Field Maps Designer app, follow these steps:
  1. Open the Field Maps Designer app.
  2. Navigate to the layer for which you want to manage feature templates.
  3. Tap on the 'Templates' tab, which contains the list of existing templates for that layer.
  4. To create a new template, tap on the 'Add Template' button and provide the necessary information.
  5. To edit an existing template, tap on the template you want to modify and make the desired changes.
  6. To delete a template, swipe left on the template and tap on the 'Delete' option.
Hope that helps!
