Multiple Pop-up Configuration For Single Layer
1548
01-28-2021 11:41 AM
RomanFox
Hello all,
I am just diving into configuring pop-ups.  Is it possible to have multiple pop-up configurations associated to a single layer?
Scenario: I have a layer that is used by field staff as an inventory of assets.  This layer is generated by field staff regularly.  I also, use this layer in a public facing dashboard.  As I configure the pop-up to focus the public facing dashboard, the field staff cannot input all attributes from the field.  Is there a way to have one configuration for the map used by field staff, and a second configuration for the map used in the public facing dashboard?
ReeseFacendini
Esri Alum
Hi @RomanFox, popups only allow one configuration per layer.  If you want to have the scenario above, the best way would be to create views of the main layer, and control which attributes are shown based on who needs to see it (employees vs. public).  Views read the updates from that main layer, so there is no additional editing that needs to happen.
Hope that helps
ReeseFacendini
Esri Alum
Hope that helps
