Multi Select Combobox
692
02-21-2020 06:47 AM
jaykapalczynski
Honored Contributor
I have a project up and trying to outline a few ideas.
I want to add a point and add attribute info.  No Big deal there.
But then I have to try and record that location which contain multiple counties (that location supports multiple counties)
I dont want to create polygons, I would rather stay with the point location, as there might be overlap between the locations supporting the same county.
That being said I was thinking of a related table or a field that will hold an array of some sort...
Where I could:
1. Select the drop down combobox and choose multiple counties and it stores these values in a field in the FC
2. Select the drop down combobox and choose multiple counties and it stores in the related table
I would much rather use option one above.  My question is this possible?  Can I select multiple values in a combobox and write those values to a single field in a FC via AGOL web map?
jaykapalczynski
Honored Contributor
Or could I select multiple counties in the map and then write those values to a field in the point FC....I actually like this option the best....but I assume I would have to write this in a JS app that I create not via AGOL Editing.
