Maps1 ArcGIS service down
1938
6
06-09-2022 12:13 PM
MM598
KenBuja
MVP Esteemed Contributor
Waffle_House
Is this layer maintained by Esri? Or some other org?
MM598
Yes, it seems to be maintained by ESRI.
KenBuja
That must be pretty old, since it uses http and not https. Is this service a replacement?
https://services.arcgis.com/P3ePLMYs2RVChkJx/ArcGIS/rest/services/USA_Federal_Lands/FeatureServer
Here's more description about it: https://www.arcgis.com/home/item.html?id=5e92f2e0930848faa40480bcb4fdc44e
MM598
The site is embedded in the JSON string on this website: https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/web-map-printing-with-arcpy-mp.htm#ESRI_SECTI.... Adding the website you suggested into my code is not working in its place.
KenBuja
MM598
That one works! Thank you!!
