Map Error In New Chrome Update (128.0.6613.85)
13986
27
08-22-2024 08:16 AM
AaronBrake
I'm a user of an application that uses ArcGIS, and with the new Chrome Update I'm seeing errors when I make a selection to view on the map.
The error I'm seeing is:
Uncaught TypeError: Failed to execute 'uniform4fv' on 'WebGLRenderingContext': The provided float value is non-finite.
at g.setUniform4fv (webgl.js:16:204)
It occurs about 50 times every time I try to make a new selection. The map now doesn't zoom in/pan to my selection anymore, but will just move a small amount while still making the selection.
Is there anything I can do to update, or is this a known issue?
Thanks in advance!
MattNicol
Aaron and I work together - we were using the ArcGIS JavaScript API 4.18 when encountering this behavior.  After updating to 4.30, it worked as expected again.
Edit:  Be on the lookout for API changes too - depending on what version you started from and go to, other functionality might break without code updates.  One example:  The Identify process has breaking changes between 4.18 and 4.30.
MathewCoyle
Honored Contributor
It may be related to the recent Chromium update. If so it requires an update on the ArcGIS Enterprise deployment.
https://support.esri.com/en-us/knowledge-base/impact-of-google-chrome-and-microsoft-edge-127-updates...
If this application is entirely hosted on AGOL that shouldn't be the cause though. Do you have any other details on the application? Is it using custom widgets? Created in an older version of App Builder/Experience?
AaronBrake
I'm not super sure what the implementation of things is, I do know that the error is coming up in the javascript file hosted at: https://js.arcgis.com/4.18/esri/views/webgl.js
Further, I can say that it seems to be an update from today. I saw the usual behavior this morning but then after refreshing chrome from this update I started seeing this behavior.
ColinWerle1
This is a great point. If application is in an ArcGIS Portal environment (10.8.1 - 11.2), you will want to ensure that you have the Portal for ArcGIS Application Display Patch (esri.com) installed. Note: As a best practice, clear the browser cache and re-launch the browser after installing the patch.
It may be a good idea to log a technical support case to continue looking into this as well, perhaps with the SDK team.
MattNicol
DannyKing
We are using the ArcGIS JavaScript API 4.18 as well. If updating to 4.30 is not an immediate option, do you know of a way around this error? Is there a Chrome setting or flag to get around this? Will we have to tell our customers to not upgrade or downgrade their Chrome browser until we can deploy and update to their application with the latest API?
MattNicol
I'm not sure, unfortunately.
The rest of this is pure conjecture, so take it with a grain of salt.  😀
Given the original error, it seems like an interaction between how Chrome handles floating point values and the results of the math that the ArcGIS JavaScript API is doing.
The reference to a "non-finite" number could refer to something like a JavaScript Infinity or NaN.    The previous version of Chrome probably just essentially ignored it before, but (probably correctly) breaks on it now.
Whatever that calculation involved was seemingly updated sometime after 4.18 such that the result is either not calculated in the first place or no longer returns the "non-finite" number.
That's all a long-winded way of me saying, unless there's a flag you can set in Chrome to change how it handles the "non-finite" number, updating the ArcGIS JS API version is likely the only realistic option.
MichaelVolz
Esteemed Contributor
Do you know what the lowest ArcGIS JavaScript API version that would resolve this issue?
My org has one web app at ArcGIS JavaScript API version 4.29 and this issue does not exist there.  We have another web app at a different version I think (Not sure), where this exact issue is occurring.
MattNicol
I don't unfortunately - we jumped directly from 4.18 to 4.30.  If you need the minimum version where this is fixed, I'd just keep incrementing the version number until you find where it works.
DevServiceTitan
4.20 seems to be the lowest version that resolves the issue
