You will need to create your own static methods to change these--At least I have not seen any in the runtimes ??
though its pretty easy -- here is a utility class that I created for c# should be pretty easy to convert to Objective C and Java
so the key is the MapPoint
public static string ddToDms(double coordinate, bool dm)
var neg = coordinate < 0d;
var dms = string.Empty;
coordinate = Math.Abs(coordinate);
var d = Math.Floor(coordinate);
coordinate -= d;
coordinate *= 60;
var m = Math.Floor(coordinate);
coordinate -= m;
coordinate *= 60;
var s = Math.Round(coordinate);
char pad;
char.TryParse("0", out pad);
var dd = d.ToString();
var mm = m.ToString().PadLeft(2, pad);
var ss = s.ToString().PadLeft(2, pad);
if (!dm)
dms = string.Format("{0}°{1}'{2}\"", dd, mm, ss);
else
var pMin = (s / 60) + m;
var msFormat = string.Format("{0:0.####}", pMin);
dms = string.Format("{0}°{1}'", dd, msFormat);
if (neg)
dms = "-" + dms;
return dms
the bool is for Decimal minurtes if true will give you the Decimal Minutes
this is the static method that I created for C# but using the Java you would be able to call String.Split() returns an array and for Objective C
send the message [@"string" ComponentsSeperatedByString:@"this is the char to separate by"] to a NSArray *var
P.S. thanks Chris Bradberry I stole a lot of the original logic from him
