Latitude and Longitude Display on Mobile Devices
1407
02-09-2012 06:35 AM
NDFResource
I have an arcgisonline app developed to assist wildland fire fighters. I have 2 questions:
1) When I try an get latitude and longitude for a point on a mobile device (Ipad or android), it displays as decimal degrees. Is there a way to display it on mobile devices in degrees minutes seconds.
2) Is there or will there be functionality to be able to enter a latitude and longitude and have the app zoom to that location
John
MichaelWaltuch
Not at the present time.
On the list.
SteveGoates1
Wondering if it is possible yet to display Minutes / Seconds on mobile devices?
BrianLocke
You will need to create your own static methods to change these--At least I have not seen any in the runtimes ??
though its pretty easy -- here is a utility class that I created for c# should be pretty easy to convert to Objective C and Java
so the key is the MapPoint
       public static string ddToDms(double coordinate, bool dm)
            var neg = coordinate < 0d;
            var dms = string.Empty;
            coordinate = Math.Abs(coordinate);
            var d = Math.Floor(coordinate);
            coordinate -= d;
            coordinate *= 60;
            var m = Math.Floor(coordinate);
            coordinate -= m;
            coordinate *= 60;
            var s = Math.Round(coordinate);
            char pad;
            char.TryParse("0", out pad);
            var dd = d.ToString();
            var mm = m.ToString().PadLeft(2, pad);
            var ss = s.ToString().PadLeft(2, pad);
            if (!dm)
                dms = string.Format("{0}°{1}'{2}\"", dd, mm, ss);
            else
                var pMin = (s / 60) + m;
                var msFormat = string.Format("{0:0.####}", pMin);
                dms = string.Format("{0}°{1}'", dd, msFormat);
            if (neg)
                dms = "-" + dms;
            return dms
the bool is for Decimal minurtes if true will give you the Decimal Minutes
this is the static method that I created for C# but using the Java you would be able to call String.Split() returns an array and for Objective C
send the message [@"string" ComponentsSeperatedByString:@"this is the char to separate by"] to a NSArray *var
P.S. thanks Chris Bradberry‌ I stole a lot of the original logic from him
