Labeling Stacked Features
275
06-09-2026 11:08 AM
LoganCaruthers1
Hello Everyone,
I am having some trouble with labeling stacked features. I have a location with three points stacked directly on top of one another as they share the same Lat/Long. Visually, you only see one feature which is the one draw on top, however when I enable labels the label that appears is not for the feature drawn on top.
Is there a way for the label to be for the feature / records you can see or that is drawn on top?
RussRoberts
Esri Notable Contributor
You can do a couple things
- Under label style you can set a different placement location for each of the label classes and use the XY slider to manual adjust that position within the updated anchor location.
- Disabling deconfliction. This will keep all the labels present for the class that has deconfliction disabled.
These topics get covered in this blog here:
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/map-viewer-a-labeling-recap
