Labeling does not transfer to AGOL with publishing from ARC Pro
2380
6
08-29-2023 07:53 AM
Labels (3)
RodneyParker
If you can create it in arc map or Pro, why does it not transfer to AGOL.  This makes absolutely no sense.  Please help.
ClayDonaldsonSWCA
The labeling engine in online maps is different than pro - so not all settings transfer. I would suggest setting up the labels in the map viewer, so you can see the limitations.
Configure labels (Map Viewer)—ArcGIS Online Help | Documentation
RodneyParker
This did not work either.  I am attempting to have the interstate shield appear on the interstate in AGOL.
ClayDonaldsonSWCA
If you are working with highway shields - I would use  Vector Tile Style Editor (arcgis.com)
Highway shields are vector symbols, not a font supported in AGOL. Alternatively, you can publish points with those symbols.
RodneyParker
See attached pic from Pro.
RussRoberts
Esri Notable Contributor
To do highway shields the labeling should be done within the symbol.  When you author the symbol the structure might look like this with a marker symbol using a text symbol and symbol property connection to the field.
Sample web map
https://jsapi.maps.arcgis.com/apps/mapviewer/index.html?webmap=24e519d4508747a8a7789230eaaafe10
LIZDean
I agree, what's the point of getting it looking good in ArcGIS Pro and then having to redo which heavy limitations in AGOL 😞
