Is it possible to apply different symbology types to different map scales?
1659
7
07-15-2024 06:39 AM
NiColahh
This may not be feasible but I'm wondering if it's possible to apply different symbology types to a layer at different zoom scales (e.g. single symbol when zoomed out and unique values when zoomed in)? For example, I'd like to show different transportation systems (lines) by color when zoomed out, and break down the colors of bus systems by route when zoomed in. Is it feasible via Arcade or otherwise? Ultimately, we would like to publish a web map in ArcGIS Online.
Lee_Butler
A simple solution would be to create multiple copies of the transportation layer in your web map each symbolised differently and set to display at different scales. This way one layer would disappear as you zoom in but a copy of the layer, symbolised differently would appear in its place.
NiColahh
I think this sounds like the best option and should work. Thank you, @Lee_Butler.
jcarlson
MVP Alum
There is the $map_scale global variable that you can access in the symbology Arcade editor, but it's not going to give you a nice consistent output like you want. I think @Lee_Butler 's suggestion is the way to go.
- Josh Carlson
Kendall County GIS
NiColahh
@jcarlson, that's helpful to know--thank you keeping me from going down a rabbit trail.
Georgios-NektariosTselos
Hi @NiColahh ,  one potential solution to your issue could be the creation of domains. You may create several domains and then manage your data and categorize them using the attribute table. Subsequently, you can choose different symbols for each domain from the symbology settings.
Please find a helpful link for 'Create and manage domains' https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/create-modify-and-delete-do... . I believe this resource will assist you in addressing your needs.
Best regards
Georgios-Nektarios Tselos
NiColahh
Thanks, @Georgios-NektariosTselos. I was thinking that domains may be more than necessary for this, but I may rethink that if I hit a wall with the solution that I'm going with. I appreciate your input and link.
MarkBockenhauer
I think what you are after, is Alternate Symbol support in ArcGIS Online, it would be good to enter an Idea similar to this one  Support for alternate scale-based symbols in ArcGI... - Esri Community  specific to webmaps and the MapViewer.
