In Survey123 Can I Multiply 2 Attribute Values Using Custom Report Template Syntax?
809
11-13-2019 08:49 AM
by Anonymous User
Not applicable
I have an hours value and a rate value that I would like multiplied when I run feature reports. Is this possible using some sort of custom report template syntax?
by Anonymous User
Not applicable
Hi Anthony,
I don't see any math functions in the report documentation (Feature report templates—Survey123 for ArcGIS | Documentation) but it's possible that Survey123 for ArcGIS‌ might have a workaround.
You could also possibly use a hidden calculate type question to multiply the fields within the survey, then reference the calculated field when running the reports.
Hope that helps,
-Peter
