Identity Manager not prompting for log in.
1109
03-14-2014 11:41 AM
GaryLaitman
I have downloaded many javascript examples including:
https://developers.arcgis.com/javascript/jssamples/widget_identitymanager_client_side.html
https://developers.arcgis.com/javascript/jssamples/widget_identitymanager.html
When I run them, the map renders but I never get prompted for my credentials. In addition when I run the Live Samples I still do not get prompted for my credentials. I am Windows 7, Internet Explorer 9.
My goal is to be able use Javascript from my .net developement environment to access/query a Web Map that is on my company's ArcGIS Online site. I assume in order to so I would first have log into the ArcGIS Online site through Javascript.
Thank you.
KellyHutchins
Esri Notable Contributor
Hi Gary,
With IE 9 you'll need to do two things in order for that sample to work
1. Setup a proxy on your web server. We have a .NET proxy available here: https://github.com/Esri/resource-proxy
2. Access the app via https which means you'll need an SSL certificate.
GaryLaitman
Thank you for your response. It certainly would help if the information you sent was included in the description of the sample.;)
