I can't share a dashboard to the public
2884
8
01-27-2023 07:10 AM
LAWRENCESUTTLE
I'm student and I created a dashboard that I want to share on my LinkedIn account. I enabled sharing with everyone on the dashboard and the layer included. I also asked the school's admin to allow anonymous access. I copied the URL of the dashboard and included it in my post. But when people try to view it, it asks to log into an esri account. Is there anything else I can do? Can I share a dashboard as link or do I need to embed it into a website? Thank you so much. Lawrence
Tags (3)
Richard_Purkis
@LAWRENCESUTTLE
Can you double check the sharing setting of content item with ID: 77411258cdc84d81a9fa413afb52fada
I do not appear to have permissions to access this resource
Richard_Purkis
Hi @LAWRENCESUTTLE
Did you also share the web map with everyone?
Failing that, may you share the url of the dashboard as this will allow us to test from our end.
Thanks
LAWRENCESUTTLE
Yes, Richard. Thank you.
BrianBaldwin
@LAWRENCESUTTLE - the issue is probably the link.
If you look at the URL of the dashboard you shared it probably looks like this: "https://brian.maps.arcgis.com/apps/dashboards/9b4232772c52472882eb178c68b18810"
You just need to take off the specific organization name in the URL:
"https://arcgis.com/apps/dashboards/9b4232772c52472882eb178c68b18810"
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
LAWRENCESUTTLE
Richard_Purkis
@LAWRENCESUTTLE
LAWRENCESUTTLE
Whose ID is this one? The Dashboard or the layer? Both of them are set to be share with everyone.
BrianBaldwin
Just drop that ID into the ArcGIS Online search pane - and it will return the item.
Then - make sure that is shared 'with everyone'.
LAWRENCESUTTLE
Hi Richard, Thank you so much! You helped me figure out: There was a layer I forget about that was not shared with the public.
