Hi! I'm working with arcade expressions and I need to summarize all values of all records that I have in a layer to asign a symbology.
Example:
| ID | Value |
| 1 | 100 |
| 1 | 200 |
| 2 | 300 |
| 2 | 400 |
I need sum (100 + 200 + 300 + 400) = 1000 of the same field, if I'll make a filter over ID = 1 I'll have sum(100 + 200) = 300
When I use the functon Sum() this only sum two o more fields but It doesn't sum all records of the same field
someone could help me with a insights how I can do it
Thank you so much
Regards
Solved! Go to Solution.
Thank you Xander Bakker for your help. We solved this doing the summarize in ArcGIS Pro and shared our layer in ArcGIS Online. We applied the symbology with the arcade expressions.
It's very interesting how you use the arcade expressions in your explanation.
