How to search our data in the ArcGIS Online?
1342
02-20-2014 11:29 PM
JamalNUMAN
Legendary Contributor
I have a sample layer that includes the parcels. I wanted to search a particular parcel based on its number (shown in the screenshot below) but couldn???t figure out how this can be done on the ArcGIS Online.
[ATTACH=CONFIG]31661[/ATTACH]
Is there a way to apply such search in the ArcGIS Online? It is a configuration issue or development?
Thank you
Best
Jamal
Jamal Numan
TimWitt
Jamal,
This blog post will tell you step by step on how to setup an application that lets you do that.
Tim
JamalNUMAN
Jamal,
Tim
Thank you for the help Tim.
But which one of these many blogs is relevant to my issue? Could you please provide the link for that particular blog?
By the way, I didn�??t mean here to search particularly parcels. What I meant is to have the ability to decide which layer and which fields are supposed to be searched.
[ATTACH=CONFIG]31682[/ATTACH]
Jamal Numan
TimWitt
Jamal,
try and open this link http://blogs.esri.com/esri/arcgis/2013/03/19/configuring-the-arcgis-online-parcel-viewer-application...
If clicking the link doesn't work try it again, sometimes it just goes to the blog page and not the specific blog. If all else fails just copy paste the link.
You can set that template up to search for other things too, they just call it parcel search.
The search bar you are using is looking in the ESRI geocoder, it has nothing to do with the feature services in your map.
BrianFlood
You can connect the Search Bar with your Feature Services using this service: http://bitly.com/1cwXu84
It might be helpful until ESRI adds feature searching to the core platform
cheers
brian
JamalNUMAN
cheers
brian
Many thanks Tim and Brian for the help.
I�??ll be trying these two options and see if they work with me.
Best
Jamal
Jamal Numan
