The best scenario to update data (shape file) published in the ArcGIS Online,
1143
02-20-2014 11:52 PM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
The best scenario to update data published in the ArcGIS Online,
I have a layer that represent the land use as shape file. This shape file is Zipped before uploaded to ArcGIS Online. Now, as this data is updated at the desktop level, then what might be the best scenario to reflect these updates on the ArcGIS Online?
[ATTACH=CONFIG]31662[/ATTACH], [ATTACH=CONFIG]31663[/ATTACH]
Do I need to delete the web map and the web mapping application and to replace it with the updated shape file and to be engaged again with symbology and other settings again from scratch?
[ATTACH=CONFIG]31664[/ATTACH]
Thank you
Best
Jamal
by Anonymous User
Not applicable
Original User: timw1984
Jamal,
You don't need to re-do your map and application. If you need to make changes to your feature service, follow the steps outlined here.
Hope this helps!
Tim
by Anonymous User
Not applicable
Jamal,
Hope this helps!
Tim
JamalNUMAN
Legendary Contributor
Jamal,
Hope this helps!
Tim
Thank you very much for the help Tim.
Best
Jamal
Jamal Numan
