How to make an hyperlink for a field that has a path to a file in a webmap
751
10-30-2024 10:00 AM
SanchezNuñez
Good afternoon,
a field from layer stores the apth and file name
MyFile = \\server\folder\finename.tiff
how can I show this file in a web map popup window and make it clickable (hyperlink).
Can it be done with Arccade?
Thanks
jcarlson
MVP Esteemed Contributor
You cannot write a valid local link using a web map, you need to serve the files out using a web server as @Laura  has mentioned. Any URL that doesn't start with a valid prefix will be scrubbed out by the web map itself.
http, https, tel, and mailto all work. Most everything else will get removed.
- Josh Carlson
Kendall County GIS
Laura
by MVP Regular Contributor
For mine I use the text option as a pop up.  From there I insert the link and path.
https://your server site (path/attribute column)
this is all accessed through IIS and all of the files are accessible to the GIS server that it reads from.
https://community.esri.com/t5/arcgis-online-questions/arcgis-online-virtual-directory-access/td-p/33...
jcarlson
- Josh Carlson
Kendall County GIS
