Publishing Hosted Feature Layer from GDB Clears out Data
764
10-30-2024 09:17 AM
KansasDASC
I'm working with Oracle SDE layers to convert them to GDB feature classes and tables. I'm also building relationships between the feature class and a number of tables. When I zip the GDB and upload it to AGO, all the tables and feature class look good and show data after publishing as hosted FL, except for one table. The one table just shows a message "No Data Found".
If I publish without setting relationships, same thing. If I upload the GDB, publish it, then download the original GDB, the data are there, but if I export the hosted FL to a new GDB, then download that, the table in question has zero records. It seems to be isolated to the publishing FL process in AGO that is emptying the table out.
All data are coming from the same source and when converted to GDB FC and tables, the data are good at the Pro level.
Any thoughts or considerations for something like this?
