How to download photos from a hosted feature layer
1879
03-08-2022 01:13 PM
ACA
I have a hosted feature layer "TREEINSPECTIONS" that contains a related inspection table and associated photos. The photos are visible through Field Maps.
I have tried downloading the  "TREEINSPECTIONS"  feature layer, which includes the related inspection table but there are no photos included in the download. I am downloading as a FGDB. See image below.
Am I doing something wrong to get the photos?
Katie_Clark
MVP Regular Contributor
You'll need to run a script to extract the BLOB data from the table and create the image files. You can follow this workflow to do that.
https://support.esri.com/en/technical-article/000017450
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
Katie_Clark
When you download the fgdb, it should include all layers and tables unless you've specified otherwise with a query. The photo data is stored as BLOB data in the table with _ATTACH
Best,
Katie
- Simon Sinek
ACA
Thanks Katherine:
I see the name of the photo in the _ATTACH table but where is the actual photo? I don't see it in the downloaded zip file.
Katie_Clark
Best,
Katie
- Simon Sinek
ACA
Thanks Katherine!
This worked perfectly!
