How to create a web scene layer to share in ArcGIS Online from .MPKX
2414
9
08-01-2022 02:57 AM
ThamerTarabzouni
I have received a file ArcGIS Pro Map packages files (.MPKX) that contain 3D modeling for a site. I opened it using the ArcGIS Pro 2.9.
How to produce a scene layer from so I can work with in ArcGIS Online or ArcGIS Enterprise?
Thanks.
Tags (3)
RussRoberts
Esri Notable Contributor
What kind of data is it(points, BIM, multipatch)?
Are you viewing the content in a scene in Pro?
Do you have an organizational account or what version of enterprise do you have?
Some helpful doc
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/share-a-web-scene.htm
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/web-scene-layer.htm
ThamerTarabzouni
What kind of data is it(points, BIM, multipatch)? It's BIM most probably
Are you viewing the content in a scene in Pro? Yes.  as local Scene.
The problem when I use the option to share it as a layer package so I can then view it in ArcGIS Online, I got the following errors despite the analysis step is successfully completed. It seems I'm missing something
RussRoberts
you will need to share this as a web scene and publish a scene layer during that process. layer packages are not viewable in web apps.
ThamerTarabzouni
This is what I know, but the only options displayed are presented below. and ArcGIS Online doesn't open .Lyrx files.
RussRoberts
Do you have an organizational account with publishing privileges
ThamerTarabzouni
Yes I do.
RussRoberts
When you go to properties on the BIM layer what is the source for it?
ThamerTarabzouni
Hi, Sorry for my late answer .
I'm note exactly sure what is your question about, but hopefully the below screenshot would be providing that.
I hope now your can provide assistance to know why I can't publish it to ArcGIS online/
RussRoberts
That is a scene layer package. You can do either Share Web Scene which will upload that package and publish a scene layer from it or upload that package directly through ArcGIS Online> My Content > Add Item
