How to Create a shape map from Zip Code or County List
3177
03-23-2023 04:13 AM
PatrickCox
I am new to mapping so sorry if this is a basic question...
I would like to create a map that groups county or zip code shapes into larger shapes and then export this as a KML or GeoJSON file for use in Power BI.  When I create a layer in the product from my list of counties for example, I only see dots, not shapes.  So I would appreciate any suggestions for this.
Attached is an example of what I would like to end up with.  thanks for any help!
Tags (1)
Omar_A
by Esri Contributor
You can use the Dissolve tool in ArcGIS Pro. Once you have created the dissolved layer, you can export it as a KML or GeoJSON file for use in Power BI.
Omar_A
by Esri Contributor
PatrickCox
Thanks for your reply.  This was part of the solution.  I was able to reach someone from Esri support to walk me through the entire process.  It was basically Select, Dissolve, Merge, Export.
Thanks again.
