How copy map service from one ArcGIS server to another ArcGIS server
36741
26
03-25-2013 02:19 AM
Rakibul_IslamRoni
Hi, I need to copy Map service which is created in ArcGIS server 10.1 (sp1), to another ArcGIS server (10.1 sp1) machine. I am trying to do this process manually by copying service file from C:\arcgisserver\config-store\services and C:\arcgisserver\directories\arcgiscache and *.JSON files. Service can read by new machine but cannot start the service. So please give a direction that how can i do this work.
IreneEgbulefu1
Rebecca Strauch‌, Emily Keefer-Cowles
Hello Rebecca, I am happy to note that you actually got this tool to work at your end. I am currently trying to use the tool to copy some bunch of map services from my existing ArcGIS Server 10.4 to a new ArcGIS Server 10.4 but I keep getting this error
Directory not copied. Error: [Error 3] The system cannot find the path specified: u'E\\arcgisserver\\directories\\arcgissystem\\arcgisinput\\NaturalResources\\MS4_Map_SupportingLayers_Public_Viewer_Natural_Resources.MapServer\\*.*'
Service MXD not found.
I don't understand why it is displaying the 'drive E' without the colon. Is this right?.
These are the paths I specified for the system sysTemp field
E:\arcgisserver\directories\arcgissystem\arcgisinput\sysTemp
for the backupTemp
E:\arcgisserver\directories\arcgissystem\arcgisinput\backup
  Both 'sysTemp' and 'backup' folders were created in my new ArcGIS 10.4 Server which is the destination server. I didn't fill anything in the 'Destination_Folder' field
I have tried to follow all the steps you stipulated above unfortunately I'm still not able to get it to run successfully. Please can you explain more  details of what exactly you did to get the tool to work for you.
I have over 280 map services I need to copy and would really be happy if this tool could work for me. That would make life much easier for me.
thanks
RebeccaStrauch__GISP
Hi Irene,
I was getting the same error, and I used arcpy.AddMessage or print statements to print out the variables and the approximate line number in my code (to I could find it easily).    For my use, I used the V101 folder to grab my .mxd.  I've included a snip of the code with my comments.  I did several other changes after I resolved this, like read my admin credentials from an ini file vs hardcoding them, so my record numbers in my comments might be off.
...oops, need to open this in another browser tab to post my code...
Look at about line 76 below to see my comments
      else:
        arcpy.AddMessage("\n  ** Service '" + str(service) + "' information read successfully. Now transfering... (5 steps)")
        # Deserialize response into Python object
        propInitialService = json.loads(data)
        user = getpass.getuser()
        pathInitial = propInitialService["properties"]["filePath"]
        #arcpy.AddMessage("pathInitial line 653: {0}".format(pathInitial))
        pathInitial = pathInitial.replace(':', '$', 1)    # this is stripping the ":" from d:\  with $
        #arcpy.AddMessage("pathInitial line 655: {0}".format(pathInitial))
        pathInitial = os.path.join("\\\\{0}".format(fromServerName), pathInitial)    # add source server name to path
        #arcpy.AddMessage("pathInitial line 657: {0}".format(pathInitial))
        msdPath = pathInitial.replace('X', os.path.join(r'\\' + fromServerName, 'x'), 1)
        #arcpy.AddMessage("msdPath line 659: {0}".format(msdPath))
        if newFolder != "" : folderName = newFolder
        else: folderName = os.path.split(service)[0]
        serviceName = os.path.split(service)[1]
        serviceName2 = serviceName
        pos3 = serviceName2.find(".MapServer")
        simpleServiceName = serviceName2[:pos3]
        #arcpy.AddMessage("simpleServiceName line 668: {0}".format(simpleServiceName))
        if  folderName != 'root' or folderName != '':
          finalServiceName = folderName + "//" + simpleServiceName + ".MapServer"
          temp_workspace = string.replace(workspace, ':', '', 1)
          temp_workspace = string.replace(temp_workspace, 'X', os.path.join(r'\\' + socket.gethostname(), 'x'), 1)
          sources = os.path.join(temp_workspace, os.path.join(folderName, simpleServiceName + ".MapServer"))
        else:
          finalServiceName = serviceName
          sources = os.path.join(string.replace(temp_workspace, 'X', os.path.join(r'\\' + socket.gethostname(), 'x'), 1), serviceName)
        #Check if the service exists
        #arcpy.AddMessage("finalServiceName line 672: {0}".format(finalServiceName))
        serviceExists = False
        serviceExistsOld = False
        serviceExists = isServicePresent(toServerName, str(toServerPort), targetServerToken, simpleServiceName, folderName, "")
        pos = msdPath.find(serviceName) + len(serviceName)
        #arcpy.AddMessage("pos line 687: {0}".format(pos))
        inputFolderPath = msdPath[:pos]
        #arcpy.AddMessage("inputFolderPath line 691: {0}".format(inputFolderPath))
        inputFolderPath = os.path.join(inputFolderPath, "extracted", "v101")
        #arcpy.AddMessage("inputFolderPath line 693: {0}".format(inputFolderPath))
        #If service exists and must be overwritten
        if serviceExists == True and overwrite == 'true':
          #Backup old service
          serviceURLforbackup = "/arcgis/admin/services/" + folderName + "/" + serviceName
          #arcpy.AddMessage("\nserviceURLforbackup line 700: {0}".format(serviceURLforbackup))
          # This request only needs the token and the response formatting parameter
          tokenforbackup = targetServerToken # gentoken(toServerName, toServerPort, toAdminUser, toAdminPass)
          paramsforbackup = urllib.urlencode({'token': tokenforbackup, 'f': 'json'})
          responseforbackup, dataforbackup = postToServer(toServerName, str(toServerPort), serviceURLforbackup, paramsforbackup)
          #arcpy.AddMessage("\nresponseforbackup line 706: {0}".format(responseforbackup))
          #arcpy.AddMessage("\ndataforbackup line 707: {0}".format(dataforbackup))
          if (responseforbackup.status == 200) and assertJsonSuccess(dataforbackup):
            propInitialServiceforbackup = json.loads(dataforbackup)
            pathInitialforbackup = propInitialServiceforbackup["properties"]["filePath"]
            pathInitialforbackup = pathInitialforbackup.replace(':', '', 1)
            msdPathforbackup = pathInitialforbackup.replace('X', os.path.join(r'\\' + toServerName, 'x'), 1)
            #arcpy.AddMessage("\n msdPathforbackup line 715: {0}".format(msdPathforbackup))
            posforbackup = msdPathforbackup.find(serviceName) + len(serviceName)
            # doesn't handle the  d$ or share correctly
            # inputFolderPathforbackup = msdPathforbackup[:posforbackup]
            # arcpy.AddMessage("\ninputFolderPathforbackup line 719: {0}".format(inputFolderPathforbackup))
            # so using inputFolderPath which I modified above
            copyFrom =  inputFolderPath    #inputFolderPathforbackup
            #arcpy.AddMessage("\ncopyFrom line 722: {0}".format(copyFrom))
            copyTo = os.path.join(workFolder, folderName, serviceName)
            #arcpy.AddMessage("copyTo line 724: {0}".format(copyTo))
            continuePublish1 = copy(copyFrom, copyTo)
            continuePublish2 = createZipFile(copyFrom, workFolder + "\\" + folderName + "\\" + serviceName + ".zip")
            if continuePublish1 == True and continuePublish2 == True:
              arcpy.AddMessage("     Step 0: Old service backup done succesfully.")
            else:
              arcpy.AddMessage("     Step 0: Error when backing up old service .")
          serviceExistsOld = serviceExists
Remember, the line numbers in the AddMessage statements won't match yours, but I suggest adding a few like this if you still need to trace things back.  I left them in my code although, once fixed, I commented them out.
Hope this helps.
IreneEgbulefu1
Thank you so much Rebecca, I did some modifications following the steps you described above, when I ran the script, it is able to copy over some of the map services and not able to copy some. It  reported the error below which i believe could be specific to the individual map service. For these specific map services it is not able to analyze the service definition drafts and I am currently looking into this issue. Did you get similar error in yours?
Service could not be published because errors were found during analysis
 Thank you very much
JonathanQuinn
Esri Notable Contributor
It looks like it's writing the errors to a text file:
# if the sddraft analysis contained errors
else:
  #Service Definition Draft could not be analyzed
  if analyseDraft['errors'] == "NO":
    arcpy.AddWarning("     Service Definition Draft could not be analyzed.")
    content = "\n " + formatDate() + "\n Service Definition Draft could not be analyzed. \n   - " + finalServiceName + "\n"
    serviceFailureNumber = serviceFailureNumber + 1
    writeTxtFile(False, content, serviceFailureNumber, content1, workspace)
    #writeInDatabase(fromServerName, toServerName, serviceType, finalServiceName, service, user, sources, 'Service Definition Draft could not be analyzed.')
  else:
    arcpy.AddWarning("     Service could not be published because errors were found during analysis. ")
    content = "\n " + formatDate() + "\n Service could not be published because errors were found during analysis. \n " + str(analyseDraft['errors']) + "\n   - " + finalServiceName + "\n"
    writeTxtFile(False, content, serviceFailureNumber, content1, workspace)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
You can add what's stored in the content variable to the AddWarning message:
else:
  else:
    #Include the results of the analysis within the message
    messageContent = "Service could not be published because errors were found during analysis. \n " + str(analyseDraft['errors']) + "\n   - " + finalServiceName + "\n"
    #Add the message to the tool
    arcpy.AddWarning(messageContent)
    writeTxtFile(False, content, serviceFailureNumber, content1, workspace)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
This way, it prints the message but also writes to the file created by the createTxtFile function, (whatever the "workspace" variable is defined to, which appears to be the sysTemp folder path).
Good point.  I had forgotten about the log files. I do see one of my last tests I did have some failures, but more successes, listed in my logs.  Some of them had that error.    For me, I'll be able to review/analyze and fix and/or recreate them.
Irene....how many of the 280 gave you errors?
IreneEgbulefu1
So far I tried to copy about 59 services at a time but it is only able to transfer 24 successfully while complaining that the remaining 23 services could not be transferred because errors were found during analysis.
When I analyzed  some of the individual services it was having issues with, I noticed that there were some warning errors (not critical errors)  like projection issues and so on. These are just warnings and not error.
I wonder why it wouldn't ignore those and go ahead and publish the maps just like ArcMap would do.
IreneEgbulefu1
else:
  else:
else:
  else:
else:
  else:
else:
  else:
else:
  else:
else:
  else:
Hi Jonathan,
I have tried to include your suggestion above to my script but its not making any difference to the output. I'm just wondering how I can instruct the script to ignore
the non-critical errors in the Analysis stage and proceed to publish the service.
Some of the errors include discrepancy in the map projection, layer draws at all scale etc.
Is there a way to tell the script to bypass some of these non critical errors and publish the service
--inputFolderPath line 691: \\Hamiltonpool\E$\arcgisserver\directories\arcgissystem\arcgisinput\NaturalResources\MS4_Viewer_RegBoundaries.MapServer
inputFolderPath line 693: \\Hamiltonpool\E$\arcgisserver\directories\arcgissystem\arcgisinput\NaturalResources\MS4_Viewer_RegBoundaries.MapServer\extracted\v101
Step 1: Creating Service Definition Draft (.sddraft)
Step 2: Analyzing Service Definition Draft.
The following information was returned during analysis of the MXD:
JonathanQuinn
Since it's going into the else block, (line 777 in the original script on github), what I would do is print the results of the analysis:
Ex.
arcpy.AddMessage(analyseDraft)
This is a simple way to see why it's reaching that else block.  It looks like the analyseServiceDraft is already going through the messages within the analysis starting on lines 1178, so from your output, it doesn't seem like there are any error messages.
def analyseServiceDraft(draftXml, service):
    analysis = {}
    try:
        # Analyze the service definition draft
        analysis = arcpy.mapping.AnalyzeForSD(draftXml)
        # Print errors, warnings, and messages returned from the analysis
        count = 0
        mess = "     The following information was returned during analysis of the MXD: "
        for key in ('messages', 'warnings', 'errors'):
            mess = mess + "\n      " + key.upper() + ":"
            vars = analysis[key]
            mess2 = ""
            for ((message, code), layerlist) in vars.iteritems():
                mess2 = mess2 + "\n      - " + message + " (CODE %i)" % code
                mess2 = mess2 + " applies to:"
                for layer in layerlist:
                    count = count + 1
                    mess2 = mess2 + "\n            " + str(count) + " : "+ layer.name
            mess = mess + mess2
            if analysis['errors'] != {}:
                analysis['errors'] = mess
                arcpy.AddMessage(mess)
            return analysis
    # if the sddraft analysis fails
    except:
        analysis['errors'] = "NO"
        return analysis
IreneEgbulefu1
691: \\Hamipool\E$\arcgisserver\directories\arcgissystem\arcgisinput\Public\Bike_Safety_Committee_Project.M...
693:Hamipool\E$\arcgisserver\directories\arcgissystem\arcgisinput\Public\Bike_Safety_Committee_Project.MapServer\extracted\v101
      - Layer draws at all scale ranges (CODE 30003) applies to: Is this supposed to be a critical problem
            1 : Commissioner Precincts
            2 : Public Schools
            3 : Bike Safety Committee Recommendations 2013
            4 : Existing Bike Routes
            5 : CoA's OCG Trail (Built)
            6 : Travis County Park Trails
            7 : County Maintained Roads
            8 : County Rds by Treatment Types
            9 : County Rds by Condition
            10 : Corridors_TNRs
            11 : CAMPO 2035 Plan
            12 : Travis_County_Parks
            13 : LCRA_Parks_All
            14 : COA_Parks_All
            15 : Other_Juris_Parkland_All
            16 : State_Parks_All
            17 : City Limits
            18 : ETJs
            19 : County_Boundary_Line
In some cases it doesn’t even return any message
Irene Egbulefu    I edited your last response so it didn't include my previous response, quoted, twice.  But it doesn't look like your error message got pasted.  you may want to try again.  oh, never mind...the green was the error message.
I do not have anywhere the number of services you have to move over, but it won't surprise me if all mine do not come over cleanly either.  Keep in mind that I made sure my data was copied over to the new server, if needed, and made sure all my data links were also set up exactly the same, that is,same names.  My guess is that is there is anything that is "broken" in the source service, it will have issues copying over.
