Here's a geocoding question about adding the XY field.
628
05-24-2019 10:56 AM
JackBuckley3
I thought I could import a CSV file into ArcGIS online and then add XY coordinates to the attribute table- but, it seems like one needs to be using Desktop or online Pro in order to be able to do that.  I don't see that ArcGIS Online allows the user to add the XY coordinates as one can do using Desktop. Is this correct?
MarisaClaggett
Hi Jack,
I would recommend up voting this idea on Geonet!  At the moment, you cannot add XY coordinates to a web layer or CSV in AGOL.  You can however, pull in the web layer to Pro, and run the Add XY Coordinates tool on it there.
https://community.esri.com/ideas/12948-add-x-y-coordinates-in-web-map-layer
Hope this helps!
Best,
Marisa
JackBuckley3
Thank you, Marisa.
Very helpful!
Jack
PS- By "upvoting" do you mean getting lots of people to request the functionality be added to ArcGIS Online?
