Help creating dictionary lookup from variable
2687
06-13-2023 09:00 PM
LindsayRaabe_FPCWA
MVP Regular Contributor
I'm trying to write an expression to create custom symbology in a feature service. Currently I've made it this far:
var ftype = $feature.Feature_Type
var label = $feature.Label
var symbol = Replace(Replace(Replace(Replace(iif(ftype == "Hazard",iif(label == "Asbestos","Asbestos Hazard","Hazard"),ftype), ' ' , '' ), '(' , '' ), ')' , '' ), '-' , '' )
var d = Dictionary('Bore', 1, 	'ExternalGate', 2, 	'ExternalGateLocked', 3, 	'GravelPit', 4, 	'Hazard', 5, 	'AsbestosHazard', 6, 	'Helipad', 7, 	'House', 8, 	'InternalGate', 9, 	'NoAccess', 10, 	'OtherInfrastructure', 11, 	'PhoneReception', 12, 	'Shed', 13, 	'WaterPoint', 14, 	'WaterPointTank', 15)
var category = d.symbol
return category
The Replace functions are removing any spaces, brackets and dashes from the value returned from the $feature.Feature_Type value and work fine. The issue I'm having is I can't get the number value out of the dictionary using a variable as an input. I know this must be possible (or it would be pointless having dictionaries) but I can't figure out how to get the d.symbol (line 7) to use the value returned at line 4.
If I change line 7 to say:
var category = d.Bore
...then it all works. As soon as I change d.Bore back to d.symbol then it fails (even though the variable symbol is returning "Bore").
I also tried formatting d.symbol through text concatenation, but that didn't work either.
Lindsay Raabe
GIS Officer
Forest Products Commission WA
JohannesLindner
So there are two ways to retrieve (and set) values from a dictionary:
var d = {"A": 1}
// Dot notation
Console(d.A)  // 1
d.B = 2
Console(d.B)  // 2
// Bracket notation
Console(d["A"])  // 1
d["C"] = 3
Console(d["C"])  // 3
The dot notation is quicker to write and (imo) easier to read, but it does not resolve variables. In your case, it looks for the key "symbol", doesn't find it and raises an error.
To make this work, you need the bracket notation:
var category = d[symbol]
Have a great day!
Johannes
JohannesLindner
var d = {"A": 1}
// Dot notation
Console(d.A)  // 1
d.B = 2
Console(d.B)  // 2
// Bracket notation
d["C"] = 3
Have a great day!
Johannes
LindsayRaabe_FPCWA
Awesome. Thank you. I'll give that a try tomorrow.
Lindsay Raabe
GIS Officer
LindsayRaabe_FPCWA
This worked a treat. Thanks. Final code below (changed the way the iif statements worked as well as they weren't returning the expected results - now uses a function to compare labels meaning it can find any Asbestos reference and not just in "Hazard" points).
function HazCat(txt,type) {
    if (Find("Asbestos", txt, 0)>-1) {
        return "AsbestosHazard";
    } else {
        return type;
var symbol = Replace(Replace(Replace(Replace(HazCat(label,ftype),' ' , '' ), '(' , '' ), ')' , '' ), '-' , '' );
return category
Lindsay Raabe
GIS Officer
