Fixing Overlapping Labels in Field Maps
1113
06-04-2021 02:37 PM
Labels (2)
by Anonymous User
Not applicable
Hey all!
Fairly simple question for this issue with a screenshot below.
Essentially some areas have two or more points at the same coordinates as multiple occurrences were recorded there and each have a unique point. I want to have these labeled in a webmap, however for the areas with multiple points, the labels just overlap each other. I tried adjusting label placement, but that just moves all labels to wherever I designate it to.
Is there a way to set label weights or something similar for webmaps so these labels display but don't overlap? Or is that just a current limitation of the label engine for ArcGIS Online?
Thanks in advance!
