Feature Size -- Legend Widget in Experience Builder
1748
10-18-2024 10:16 AM
CS_VT
I'm trying to build a web app.
The symbology example in the legend is comically small. We're talking about point features here. They are set to resize automatically in the map, but it appears that also dictates the size of the example feature in the legend. This isn't great.
At full extent, when the thousands of features look reasonably pleasant in their masses, the legend appears to feature 5 point features displayed at something that's extremely small.
Any thoughts? Help?
CS_VT
This is also true if you turn on the Show Legend in the Layer widget as well. WHY OH WHY IS THIS THE DEFAULT?
Laura
by MVP Regular Contributor
In Pro this is the workflow to follow: https://support.esri.com/en-us/knowledge-base/how-to-change-the-size-of-point-symbols-in-the-legend-...
You could try a similar workflow in AGOL and just exclude the smaller points from being shown in the legend.
CS_VT
Thanks! I'll give this a try and see if I can get it to work. Thanks.
