Is it possible to move a point's location in ArcGIS online (AGOL)?
6426
6
06-18-2020 05:13 PM
adamwade1
I've seen a couple videos on youtube that indicate it's not possible. I've used AGOL to edit ine and polygon geometry, primarily in collector. However, I've never tried to move a point's location in AGOL. After uploaded a point file into a Group project in AGOL I noticed a few points were slightly mislocated, probably due to GPS error in the field. When I click on the point I can edit it's attributes, but I'm unable to move the point.
Cheers!
-Adam
ChristianWells
It's possible in the new Map Viewer (BETA) to update a single point feature. Here is how I accomplished the task:
  1. Go to Content and find Feature Layer.
  2. Click the ellipses (...) on the Feature Layer and select "Open in Map Viewer (BETA)."
  3. On the right-hand side of the Map Viewer, select "Edit."
  4. In the Editor pop-up, select "Edit Feature."
  5. Select the feature you want to move.
  6. Click and drag the point to the new location.
FYI Peter Klingman
ChristianWells
FYI Peter Klingman
ChristianWells
Check out more of what the Map Viewer Beta can do here, connect with others, and provide feedback on the experience:
ArcGIS Online Map Viewer Beta
adamwade1
Thanks Christian! After updating the point's location it appears as if there are two points with the same attributes. However, refreshing the screen I see only the modified point is saved within the map and feature service.
I'll have a read through Beta article you shared.
Cheers!
-Adam
ChristianWells
Great! I'm glad this worked out for you.
-Christian
cpbride2020
Is it possible to select the point by the attribute table and then move it? I have about 1,000 points that I created, one for each record. They all have the same lat/lon so they are on top of each other. My task is to geo-locate each one based on hints in the attribute table (district, village, geographic feature). When I select a record in the table, the point pile is highlighted, but it will not allow me to edit its location the way it does in ArcGIS Pro. My client does not have ArcGIS but wants to do the editing himself.
SimonFoteck
@ChristianWells  the position of the point feature changes but the lat, long values remain the same - correct?
Is there a way to also update the long, lat values to that of the new position. I am using the new map viewer.
Thanks.
