I’m working on a Field Maps setup using a hosted feature layer in ArcGIS Online. My objective is :
Visibility Control: I want users to see only the features that are within a 100-meter radius of their current GPS location.
Editing Restriction: Additionally, if users are farther than 100 meters from a feature, they should not be able to edit it. Ideally, they should get a message like “You’re too far to edit this point. Get within 100m.”
Is it something that is possible to achieve?
1. Visibility Control
ArcGIS Field Maps doesn’t natively filter features based on real-time GPS location. However, you can simulate this behavior using:
Geofences + Location Alerts
• You can define a 100-meter geofence around each feature or area.
• When users enter the geofence, Field Maps can trigger a location alert.
• This doesn’t hide features, but it can notify users when they’re near relevant data.
Custom Arcade Expression for Visibility
• You can use an Arcade expression in the layer’s filter or form visibility logic to compare the user's location to the feature’s geometry.
• Example logic:
var userLocation = $location;
var featureLocation = Geometry($feature);
var distance = Distance(userLocation, featureLocation);
return distance <= 100;
This can be used to hide fields or forms, but not entire features from the map view.
2 Editing Restrictions
This part is more feasible and elegant:
Arcade Expression in Form Editing Logic
• In Field Maps Designer, you can configure the form logic to make features non-editable if the user is too far.
• Use an Arcade expression like:
if (distance > 100) {
return false;
return true;
This disables editing and can be paired with a custom message like:
There is a community post which you may find helpful also.
Solved: Field Maps editing restriction - Esri Community
I hope this helps you in some way.
