ESRI Collector, Related Tables, Attachments, ArcGIS Online
2003
08-10-2016 10:28 AM
jameshickey
I have related tables to a feature layer in ArcGIS Online that have attachments enabled. When I take a photo for the table via ESRI Collector App I can see the photo on the app but it doesn't appear anywhere at ArcGIS Online. If I take a photo for the feature itself it will show up in the pop up at ArcGIS Online
How do we view the photos taken for the related tables via Collector in ArcGIS online?
Thank you!
James
RussRoberts
Esri Notable Contributor
You can view your attachments under the data tab in the item details for your feature layer.
The steps for accessing this are:
  • Go to the item detail page for the feature layer you are using in Collector
  • Click on the data tab
  • View the related records by picking the related table in the drop down picker or click the "View" text in the parent record
  • Attachments will be located on that related record at the end of the record.
RussRoberts
XanderBakker
Esri Esteemed Contributor
You may also be interested in the tool created by Jake Skinner​ : Show Attachments in Web Map Popup . It is a great tool!
