Embedded web map prompts viewer login
449
02-08-2020 03:20 PM
Sarah_DavisDavis
I linked results from Survey123 into a web map. Both the survey layer and the web map sharing settings are set to Everyone. When I embed the web map into a website, it prompts viewers to log in to ArcGIS online. Am I missing a place where the sharing settings need to be updated? A different survey/map combo work fine when embedded so I'm not sure what issue I'm encountering. Thanks.
KellyHutchins
Esri Notable Contributor
Do you have a link to the map you are trying to share?
