Edits to Hosted Feature Layer are suddenly not saving
1940
03-22-2020 06:49 PM
PeterMacKenzie2
I am attempting to edit a hosted feature layer in and AGOL map. I am  the owner of the data and have edits enabled. None of the edits I apply seem to save. Both geometry edits (move a point) or attribute edits (modify a field). It worked fine prior to today. It just reverts back no matter what I try. Help!
ArchitSrivastava
Hello Peter,
As per my understanding this layer is Hotsed of ArcGIS Online, however if you can confirm that it would be great. Could you please try the following:
  • Add the layer to a ne Map and try editing the Layer (is the issue specific to the WebMap)?
  • Could you try checking the response to "applyedits" request using the developer tool?
  • Are you able to update attribute information for any existing feature?
  • Try disabling Editing on the hosted feature layer and re-enable it?
Hope it helps!
PeterMacKenzie2
Thanks for the reply!
    I can't even seem to edit in the data data page of the items details page i.e. https://coname.maps.arcgis.com/home/item.html?id=8e2bbbla#data
    I did try this and appears to have suceeded, but I cannot see it in the data table / attribute table:
    No, no geometry edits or attribute edits
    I tried this, still no edit
