ArcGIS Online fails to display 3D features published by ArcGIS Pro
1617
6
03-12-2020 12:56 AM
abdullahqasrawi
I couldn’t figure out why ArcGIS Online fails to display 3D features published by ArcGIS Pro. For example, the Hight of buildings is not displayed as shown in the screenshot below.
RussRoberts
Esri Notable Contributor
When publishing from Pro set the extrusion using "Base Height" and the set extrusion will be honored in SV. You can also set the extrusion in Scene Viewer as well.
abdullahqasrawi
Russell Roberts
The problem still exist
RussRoberts
What version of Pro are you using? Can you share your webscene?
24093: Extruded features will be flattened—ArcGIS Pro | Documentation
Thanks!
Russ
abdullahqasrawi
I am using ArcGIS Pro 2.5
You can check my webscene
http://www.mediafire.com/file/hycbbv64mqwc9ck/Arrabi_3D.rar/file
RussRoberts
Can you share the web scene that you published with the feature layer also shared?
abdullahqasrawi
Web Scene
http://arcg.is/1zL418
Feature layer
http://arcg.is/1DjHHS
