Duplicate field names Duplicate field names are not allowed ERROR
3149
8
08-14-2023 05:03 PM
ECjin
In order to add this csv item to ArcGIS Online hosted feature layer, I deleted all other feature layers. However, even there has already no layer, the system still display the duplicate filed names error.
JRhodes
You have two columns named "Total Enrolments_P". (Column F and Column AB).
JRhodes
Make sure you don't have any null fields (empty columns) in the CSV.
ECjin
My data does not contain any null fields or even null values within the cells. They also don't contain spaces.
JRhodes
Are you able to share the CSV?
ECjin
Yes, please find the files attached. Thanks for your help Joseph!
JRhodes
ECjin
Thank you! I went as far as using the ChatGPT Code Interpreter to assess my work, and it didn't flag any issues lol. You spot it! Thanks again!
AsaARevels
Okay what am I missing here I have the same issue as well.
Event_TitleRecovery_Ambasssador(s)LocationPartnersDateAddressCityStateZipcodeApprox_People_ImpactedDecsPhotos        Comments
JRhodes
It's probably all the empty field names. Hard to say without seeing the actual CSV.
