Hi esri community!
I'd like to create an ArcGIS Online web map that displays netCDF files with a time dimension. The final product should allow me to use a time slider to animate climatic changes over time.
I've created maps with the desired functionality in ArcMap (10.8.1), but I can't figure out how to package the netCDF files (or any suitable derivative) for export into ArcGIS Online.
I'm also concerned about compatibility between the coordinate systems between the netCDF files (which I believe use WGS 1984) and ArcGIS Online, which defaults to Web Mercator.
Basically, I'm trying to determine how amenable ArcGIS Online is to displaying netCDF files in general and what the typical workflow is for getting the files from either ArcMap or ArcGIS Pro into an ArcGIS Online web map.
Thank you!
Patrick
