Determine what is using what
2599
05-26-2015 09:48 AM
TonyGroeneveld
I need to do some cleanup of my AGOL account. Is there an easy way to determine what web maps are using a hosted feature layer before I delete it?
JakeSkinner
Esri Esteemed Contributor
Hi Tony,
One way you can do this is to use the ArcGIS Online Assistant.  Under 'I want to', set this to 'Update the URLs of Services in a Web Map'.  You can then click on a web map and it will list the services it is currently using.
