Data Limit on Rest Service
1434
02-08-2021 10:09 AM
SMa
I have published a feature that has a count of 11,911.  Is there a workaround to view these on the attribute table as a whole?
MichaelVolz
Esteemed Contributor
Do you want all these features to be shown on the map?
Or are you looking to limit map results for map performance, but be able to show all records in the tabular results?
SMa
I would like to show all features with all the records in the tabular result.  I know I can show all features and filter by map extent and it appears, but it times out in the attribute table when I try to display all features.
MichaelVolz
Is there a way to paginate the tabular results, so you can access all records but only a limited number of records are being pulled with each page?
SMa
I am not sure if you can do that.
