I published a hosted feature service from ArcGIS Pro. When I view the layer in the ArcGIS Online Map Viewer the dashed part of the polygon outline keeps disappearing when I zoom in and out. Is there anything I can do to get my symbology to consistently appear?
Solved! Go to Solution.
Thanks for reporting!! This isnt a release regression but It looks like an issue with overlapping boundaries, will log an issue in with JS Maps SDK and hopefully get this fixed for the next release.
Hi!
It is due to the range of visibility. You have applied different range/scale.
If you can share your map I can take a look to see if I can spot any issues.
@RussRoberts Thanks! I just added your russell_jsapi account to a group. Once you accept the invite you should be able to see this feature service https://www.arcgis.com/home/item.html?id=05c37c7695c94c06b222431b61768d0b If you go to the visualization tab of the item details page and zoom in on the Douglas County area in south western Oregon I'm able to pretty consistently see the problem shown in the screenshot.
@RussRoberts Thanks for looking into this and getting an issue logged!!
