I have a custom symbology layer that I am using in a web map (successfully) but when I try to use that web map in a web application (using the web app builder) the symbology doesn't show up how it's supposed to (pictures attached). Is this a known issue? Is there something special I need to do to the custom symbology?
These are not supported in 3.x JSAPI apps like WAB. If you use this in a 4.x app like Experience Builder the symbols will show up as expected.
Are these symbols coming from a web style?
@RussRoberts Yes, I published it from Pro.
Okay, thank you!
HI Rus - I am trying to solve a similar problem. I am publishing from ArcPro with no errors or warnings, using what i consider pretty basic styles. Any suggestions?
I want this:
But get this:
Few questions:
Are you publishing a web layer or a web map?
You probably have the option to publish compatible symbols unchecked in Pro. Here are some links that can help out.
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/share-a-web-map.htm
Follow up - any specific reason you are using WAB vs. instant apps or experience builder? WAB currently has a retirement roadmap outlined here
Hi Russ - Turns out this relates to a recent ArcGIS Pro update, All I needed to do was to tick the check box here: Thanks for your assistance
@Psoralea thank you for posting this! We're in the process of migrating from web app builder to experience builder but I had to update an authoritative layer today and the symbology wouldn't show up even if I changed it after the fact in the map viewer. This little check box worked like a charm!
