Create a FeatureSet from an Array...
2334
05-03-2023 01:22 PM
DJB
I'm trying to create a FeatureSet from an Array.  I've setup a for loop to cycle through the array and add a new row for each record in the array.  The issue that I'm running into is I cannot figure out how to add a new row.  So I am always overwriting the previous record.
My array is  YearList = [2018,2019,2020,2021,2022,2023] and I would like a table like:
YearFID
20180
20191
20202
20213
20224
20235
var YearList = [2018,2019,2020,2021,2022,2023]
for (var Yr in YearList){
  var yearDict = {fields: [{alias: "Year",name: "Year",type: "esriFieldTypeInteger",}],spatialReference: '',geometryType: "",features: [{geometry: "",attributes: {Year: YearList[Yr]},}]};
return FeatureSet(Text(yearDict));
Any suggestions would be greatly appreciated.
Thanks everyone.
~Dan
jcarlson
MVP Alum
You are defining your yearDict object inside the loop, so it's getting recreated every time, losing any previous entries. Define it first outside of the loop, and use your array to populate the features array within it:
var yearDict = {
  fields: [{alias: "Year", name: "Year", type: "esriFieldTypeInteger"}],
  geometryType: "",
  features: []
  Push(
    yearDict['features'],
    {attributes: {Year: YearList[Yr]}}
Also, you don't need to specify the geometry or spatial reference if there isn't any.
- Josh Carlson
Kendall County GIS
jcarlson
MVP Alum
var yearDict = {
  geometryType: "",
  features: []
  Push(
- Josh Carlson
Kendall County GIS
DJB
@jcarlson,
Thank you for the SUPER quick response.  Worked perfectly!
Thanks again.
~Dan
