Copy layers to a new folder in My Content?
901
09-12-2013 10:17 AM
DavidMedeiros
I'm taking over an existing ArcGIS Online project and rather than work directly in the current map services and data layers I want to copy a set to a new folder in my account so I don't disrupt the old set as I play around.
How can I copy select features and tiles I have in one folder (Branner Home) to another (Campus Base Map)?
I see that I can Move the layers over, but I'm concerned this will disrupt the current Web Map that calls those layers.
I can use Add Item in the new folder but that doesn't create a copy of the layer, it creates a "Map Image" (??) of the layer. I'm assuming this just means it points back to the original layer and if anything happens to it, my Map Image will be affected.
Is it not possible to simply clone the layer and add to a new folder in ArcGIS Online?
MikeMinami
Esri Notable Contributor
Unfortunately, it is not possible to copy layers you'd have to add them again via their URL to My Content. You can copy a web map by doing a "save as" when editing the web map. This copy will be independent of the original, although will reference the same layers.
Mike
DavidMedeiros
Mike
So am I right in thinking that by adding them via the URL to my new sub folder in my content, that this is not an independent file but a reference back to the original file location. If the original file changes or is deleted my "copy" will be changed as well?
